Date/Time: Mon, 16 Sep 2024 19:10:21 +0000
enter a position only on trade dom
View Count: 816
[2015-07-07 14:38:37] |
User52247 - Posts: 26 |
Hi, I would like to change stop and target on the graph, I would like to enter a position ONLY on trade dom, But I don't want to enter a position on graph because at present if I click on graph, I enter a position !! What I must to do ? Thank you for your answer ad101166 |
[2015-07-07 15:55:15] |
Go to the chart and disable: Trade >> Trading Chart DOM On Please describe precisely what you are doing which causes this: I click on graph, I enter a position !!
The only place where this could occur is if you enter an order on the Chart DOM Buy or Sell columns. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-07 15:55:32
