Date/Time: Sun, 22 Dec 2024 05:27:15 +0000
IB log off solution
View Count: 770
[2015-07-06 21:29:48] |
User911705 - Posts: 89 |
Every day, IB's TWS forces a log off (and TWS shuts itself down, and I don't recall TWS doing this in the past). Is there any way have Sierra reconnect to TWS? I have the check box for "reconnect on failure" checked. I am familiar with the open source IB Controller, but was hoping to avoid any additional software to run automated systems through TWS. |
[2015-07-06 21:50:43] |
You do only need to enable "Reconnect on failure" as far as Sierra Chart is concerned. However, this is not going to restart Trader Workstation. This would require a scheduled task to start Trader Workstation. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
