Date/Time: Wed, 05 Feb 2025 04:55:39 +0000
With Heikin Ashi as main study many delta indis dont work!
View Count: 1221
[2015-07-06 18:05:15] |
User857142 - Posts: 82 |
Hi When I use Heikin Ashi study as 'Display as main price graph' all the bid/ask study don't work. They paint the bars in the same Red color and are not accurate at all! i am talking about following studies. Please help. #Ask/Bid volume difference bar #Cum Delta Bars - Trades #Cum Delta Bars - Volume #Cum Delta Bars - Up/Down tick volume |
GSIU5 3 Min #3 2015-07-06 13_03_40.215.png / V - Attached On 2015-07-06 18:04:53 UTC - Size: 63.94 KB - 450 views |
[2015-07-06 18:09:42] |
In general, these studies are not going to function or function accurately when you display the Heikin-Ashi study as the main price graph.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-06 18:10:03
[2015-07-06 23:12:13] |
In the next release there will be support for these studies with the Heikin-Ashi study. Refer to this image: http://www.sierrachart.com/image.php?l=1436224222373.png Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
