Date/Time: Fri, 22 Nov 2024 23:53:14 +0000
Velocity customer, created new Sierra instance with IQ Feed
View Count: 1678
[2013-06-07 16:23:25] |
User79401 - Posts: 7 |
I just created a new account for my new IQ Feed. I now have two copies of Sierra. The second copy says I need to activate my copy when I log in. How do I do that? I also get an error in the log saying that my account is in FREE MODE. What is that? Software version: 984 | 2013-06-07 16:15:43 Current Service Package: 22 | 2013-06-07 16:15:43 Your usage time has ended. You are in FREE MODE. Features are restricted. | 2013-06-07 16:15:43 To purchase more time select Help>>Purchase on the menu. | 2013-06-07 16:15:43 Active service: SC Forex Data (FXCM) | 2013-06-07 16:15:43 Time Zone: +00:00:00 (UTC+00) | 2013-06-07 16:15:43 2013-06-07 17:15:43 Local computer clock time | 2013-06-07 16:15:43 2013-06-07 16:15:43 GMT time | 2013-06-07 16:15:43 2013-06-07 16:15:43 Time zone adjusted time | 2013-06-07 16:15:43 Time difference to server time: 0 seconds. | 2013-06-07 16:15:43 Program path: C:\SierraChartIQ\ | 2013-06-07 16:15:43 Data Files path: C:\SierraChartIQ\Data\ | 2013-06-07 16:15:43 OS Version Number: 6.1 | 2013-06-07 16:15:43 Requesting symbol settings for scfxcm. Overwrite = on. | 2013-06-07 16:15:44 Request for symbol settings completed. | 2013-06-07 16:15:44 Processed received symbol settings | 2013-06-07 16:15:44 Your current service package does not support this function. Select Help >> Purchase to upgrade your package. | 2013-06-07 16:15:51 Active service: IQFeed | 2013-06-07 17:16:37 Requesting symbol settings for dtn. Overwrite = on. | 2013-06-07 17:16:38 Request for symbol settings completed. | 2013-06-07 17:16:38 Processed received symbol settings | 2013-06-07 17:16:38 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChartIQ\Data\@ES#.dly | 2013-06-07 17:17:27 Your current service package does not support this function. Select Help >> Purchase to upgrade your package. | 2013-06-07 17:17:27 Your current service package does not support this function. Select Help >> Purchase to upgrade your package. | 2013-06-07 17:21:43 |
[2013-06-07 16:25:41] |
Your account is now activated. Please restart Sierra Chart
