Date/Time: Sun, 22 Dec 2024 05:50:55 +0000
Chart - remains in replay/fills mode
View Count: 721
[2015-07-04 16:28:07] |
ejtrader - Posts: 688 |
SC Team - I am trying out couple of trading related stats study and noticed the chart remains in Replay/Backtest Fills Mode - though replay is stopped. However when the same chart is duplicated - it shows up as simfills. Question is - How to make it in "sim-fills" mode after the replay chart. thanks http://www.sierrachart.com/image.php?l=1436027097226.png - This chart remains in Replay/backfills mode after the replay http://www.sierrachart.com/image.php?l=1436027201821.png - Same chart when duplicated - it shows up as "sim fills" - With correct position information from earlier sim-fills. Date Time Of Last Edit: 2015-07-04 16:28:43
[2015-07-05 02:25:49] |
This cannot happen automatically. This is by design. Question is - How to make it in "sim-fills" mode after the replay chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-05 02:26:01
