Date/Time: Sun, 22 Dec 2024 05:18:49 +0000
GAP calculation
View Count: 1197
[2015-07-03 10:52:34] |
EuropeanTrader - Posts: 290 |
Hello, is there an indicator available that would simply show me the difference in pips between the closing and opening price on my custom chart: http://www.sierrachart.com/image.php?l=1435920665684.png thank you! |
[2015-07-03 12:44:11] |
Use the Bar Difference study for this. Refer to the documentation for it for more information. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
