Date/Time: Fri, 13 Nov 2026 05:37:05 +0000
ACSIL - Tool - MultiLineLabel related question
View Count: 1222
[2015-07-03 02:41:46]
ejtrader - Posts: 689
SC Team - Would you please clarify how to define multi-line label for DRAWING_TEXT ?
Unable to find example/documentation on this.
If wanted to display the following how to format the text(in 2 lines) using multi-line label - how to format the text.
thanks
Line1
Line2
Date Time Of Last Edit: 2015-07-03 02:42:42
[2015-07-03 04:50:38]
"Line1\rLine2"
or
"Line1\r\nLine2"
You need to try both.
[2015-07-03 05:18:44]
Line1\n\Line2 - Works - Probably the most efficient one
Line1\r\n\Line2 - Works
\Line1\r\Line2 - Doesn't work
