Date/Time: Thu, 26 Dec 2024 15:38:28 +0000
quoteboard across chartbook linked charts not working
View Count: 1956
[2015-07-03 01:01:07]
User742717 Mike - Posts: 86
I have version: 1266
I have two chart books and one quoteboard linked to #1.
I create charts on chart book 1 and 2.
I link all charts to #1.
I change market on the quoteboard, the charts on chart book 1 change but the charts on chart book 2 do not.
I have the quoteboard set to always visible across chart books.
[2015-07-03 01:41:11]
Quote Board linking does not work across Chartbooks. It will only be able to control charts within the Chartbook that it is actually contained in even if it is set to be always visible.
[2015-07-03 02:28:59]
Thanks for the reply.
It's a bit confusing and a shame really as I thought that was the purpose of always visible.. maybe a feature for the future.
I guess you give yourself more link numbers keeping them seperate, ie per chartbook.
I've limited my trading to a single screen and chartbooks are great for separating long/short term charts.
I'll just duplicate the quoteboard.
Thanks again.
Edit, I guess the it's the same with link drawings/studies.. limited to chartbook.
Would be a good idea to use a class style structure.. ie chartbook1.1 chartbook2.2 etc.
Date Time Of Last Edit: 2015-07-03 03:29:44
[2015-12-10 13:41:48]
User28914 - Posts: 87
Is Quote board linking across multiple Chartbooks being added to the charts anytime soon?
[2015-12-10 17:35:43]
Regarding Chart Drawings, if you were to read the relevant documentation, you would see that it is possible to copy Chart Drawings across Chartbooks.
The documentation is there to provide the information that users require. A lot of work has gone into it.
Date Time Of Last Edit: 2015-12-11 03:33:07
[2015-12-10 18:41:16]
User80577 - Posts: 3
Hi!
[2015-12-11 03:20:29]
We will see if we can get Chart Linking working with Quote Boards when a Quote Board is set to be always visible.
Date Time Of Last Edit: 2015-12-11 03:20:42
[2015-12-11 03:32:31]
Quote Board Chart Linking will now work across Chartbooks when a Quote Board is set to be always visible.
[2015-12-11 13:51:00]
Thanks guys - you rock!
[2015-12-11 16:35:09]
Thanks a lot !!!
[2015-12-11 19:09:00]
I have tried these settings but it is not changing all the linked charts on multiple chartbooks, only changing the ones within the chartbook where the quote board was created.
Please advise.
[2015-12-11 20:15:02]
The changes to support this have not yet been released.
This will be out in about 20 minutes with version 1337.
[2015-12-15 21:41:16]
Hi There!
Chart linking does not work across multiple chartbooks. It will only be able to control charts within the chartbook...maybe a feature for the future?
I would appreciate it if you could enable the chart linking feature across multiple chartbooks.
It would be ideal for me and anyone else who is using a single screen for trading.
I would also like to Thank You for your support so far.
Regards...!
