Date/Time: Sun, 22 Dec 2024 05:37:18 +0000
No Chart Valus for Tools window
View Count: 722
[2015-07-02 18:21:37] |
joeroma - Posts: 43 |
In one of my SC instances I don't get the Chart Values for Tools Windows. I tried Windows/Restore and Windows/Tool Values Window but nothing happened. I compared the Tools Settings between instances and everything is the same. I do get a window with Windows/Chart Values Window but again not with Windows/Tool Values Window. I upgraded to v1261 but it didn't help. I don't know what the problem is. TIA
[2015-07-02 18:43:55] |
Select Window >> Reset Windows and open it again.
[2015-07-02 18:47:39] |
That worked. Thanks.
