Date/Time: Thu, 19 Nov 2026 11:12:50 +0000
Alert email error: Your email provider is blocking Alert Emails, contact Sierra Chart support.
View Count: 1244
[2015-07-02 13:04:21]
User69487 - Posts: 21
[2015-07-02 13:10:52]
What is the domain, the part after the @, of the email address you are sending to?
[2015-07-02 15:00:49]
txt.att.net
[2015-07-02 16:23:41]
Sierra Chart - Max - Posts: 5986
It is not possible to send email alerts to that domain as it is blocking our server.
Sierra Chart Support
Date Time Of Last Edit: 2015-07-02 18:09:15
[2015-07-31 12:07:38]
phaedonk - Posts: 352
I have the same problem, using a Google apps domain. I have been getting alert emails successfully for the longest time. Something changed in the past month.
[2015-07-31 16:41:48]
What is the domain of the email address used?
[2015-07-31 17:39:56]
The domain was disabled last week because 60 emails were blocked by your email server. We have unblocked the domain now, but if we do get blocked by your email server we will be forced to disable the domain again.
