Date/Time: Mon, 22 Jun 2026 16:18:20 +0000
Replay 'skip empty periods' will not skip based on session?
View Count: 2014
| [2015-07-02 08:27:36] |
| dmh - Posts: 9 |
I have a CQG F.US.ZSEX15 chart with 30 days of historical data loaded. The chart session times are set to 07:30:00 to 12:15:00 (MST). going back some days and replaying, there is always a long pause after 12:15 before it gets to next day. Increasing speed results in shorter pauses It seems to be playing through overnight session and weekends. This is the only chart in chartbook, Is there some way to get replay to respect chart session times?
| [2015-07-02 18:22:44] |
Refer to the documentation here for how this works: http://www.sierrachart.com/index.php?page=doc/doc_ReplayChart.html#SkippingData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-07-02 20:27:08] |
| dmh - Posts: 9 |
OK, I read this: "When data is encountered in the Intraday chart data file which is outside of the Session Times defined in Chart >> Chart Settings, that data is instantly skipped over and the replay continues." this is exactly what is not happening, it pauses for some time at end of every session. I increase speed to max, and about 5 seconds later the next day appears |
| [2015-07-02 20:53:44] |
What you copied is out of context. However, we do not see a problem with this. We just tested this and it instantly skipped over data outside the session times. Make sure that For All Charts in Chartbook is disabled on the Replay window and the replay mode is set to Standard Replay. There could be some other considerations but we need to know what data is in the data file, the symbol of the chart and time zone. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-07-02 20:57:53] |
| dmh - Posts: 9 |
For all charts in chartbook is disabled, it is set to standard replay. There is only one chart in chartbook, it is CQG F.US.ZSEX15 2 minute chart, with 32 days to load. Session start time 07:30:00 Session end time 12:15:00 Global time zone is set to Denver -7 MST/-6MDT and datas toriage time unit is tick. Scrolling back to eg, 5/20/2015 and trying to play through, every day does the pause I described. Would sharing the chartbook help? |
| [2015-07-02 21:04:33] |
We will test this.
| [2016-04-23 11:01:14] |
We apologize for the long delay. We have tested this. The data outside of the Session Times is instantly skipped over if Skip Empty Records is enabled. Otherwise, it is not.
