Date/Time: Fri, 22 Nov 2024 23:41:53 +0000
Daily OHLC
View Count: 1686
[2013-06-07 14:21:16] |
User26530 - Posts: 4 |
I am using several charts in the same chartbook; all intraday charts. I have one set up with session times of 0900-1430 and the other setup 1800-1715. The first is a Regular Trading Hours session and the second is a Electronic Trading Session. I am trying to place the Regular trading hour session Hi and Lo on the ETH chart and when I reference the RTH chart, the numbers that come back do not match. The Hi and Lo are very close to each other.. Can you help? Thanks |
[2013-06-07 22:51:35] |
Have you followed the instructions here: https://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s137 The only way we can help with this, is if we get your Chartbook. Please provide it by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#AttachFile The Chartbook you provide us must only contain 2 charts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-06-07 22:56:17
