Date/Time: Sun, 22 Dec 2024 05:23:19 +0000
Difference (Bar) OHLC does not work correctly
View Count: 776
[2015-07-01 15:45:53]
dmh - Posts: 9
When using difference bar with subgraph type set to OHLC, it does not work correctly. What happens is when last price sets a new high or low, then retracts from it, the whole bar resizes and does not leave a 'tail'. For example on ES, if last price is 2050.50, and then goes up to new high of 2050.75, then back down to 2050.50, the bar resizes to 2050.50, with no line extending to 2050.75. I can show a video if that is more clear
[2015-07-01 17:52:41]
Refer to this page here for the solution:
http://www.sierrachart.com/index.php?page=doc/helpdetails61.html
