Date/Time: Sun, 22 Dec 2024 05:12:00 +0000
Eurex Long Term Charts
View Count: 779
[2015-07-01 15:44:55]
User78442 - Posts: 260
Hi, I've just subscribed to SC Realtime Data and the Eurex Exchange data. I'm viewing the charts (Sep Contract, GGU15) via a second instance feed to my primary charts. My problem is I can't get the weekly and monthly charts with data further back than 2014? Also on the daily chart I can't seem to get a continuous contract working (intraday). Any ideas? tnks..
[2015-07-01 17:51:42]
If you are sharing data between Sierra Chart instances, it is not supported to use the Continuous Futures Contract feature on a chart which uses data from another instance of Sierra Chart.
Are the charts working properly on the instance connected to the Sierra Chart Data Feed?
[2015-07-02 04:22:39]
Yes. Are you saying that I need to load the data as a 1st instance on the copy of SC that the feed comes in to?
[2015-07-02 05:46:31]
For Continuous Futures Contract charts, yes.
Date Time Of Last Edit: 2015-07-02 05:46:40
