Date/Time: Tue, 26 Nov 2024 18:30:16 +0000
[User Discussion] - sc.ValueFormat for specific subgraphs
View Count: 1200
[2015-07-01 14:57:28] |
User310575 - Posts: 2 |
Hi, I would like to use sc.ValueFormat only for specific subgraphs, but not all. Is this possible? If not, is it possible to display a string in the data box? I do not actually need to graph anything, I just want to display various information in the data box. Thanks, Hector |
[2015-07-01 17:44:51] |
There is only one sc.ValueFormat setting for each study. It cannot be used individually for particular Subgraphs. What is displayed in the Chart Values windows is the data within Subgraphs. You can display text directly on the chart. Refer to this page: http://www.sierrachart.com/index.php?page=doc/doc_ACSILDrawingTools.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-07-01 18:11:44] |
Ok, but I cannot then display text in the tool values window? This is a bummer I cannot do custom formatting per subgraph. I don't want to display text on the graph, just the tool values window.
[2015-07-01 18:16:05] |
You could display text in the Tool Values window by setting the name of a particular Study Subgraph to whatever text you want to display. The names and values of Subgraphs are displayed in that window.
[2015-07-02 11:21:38] |
sampater - Posts: 244 |
It would be very usefull feature to can display at a specified index of the Subgraph not him float value but a text string. Maybe can be done an additional array of the text strings, e.g sc.Subgraph[].Text[]. Something like sc.Subgraph[].DataColor[], but instead of the coloring of the values would be display a text string if an array element of the sc.Subgraph[].Text[] is not empty. If it is empty, is displayed a standard float value of the sc.Subgraph[]. Thanks for consider this request Marek |
