Date/Time: Fri, 22 Nov 2024 23:50:03 +0000
Dashes
View Count: 1708
[2013-06-07 13:58:52]
ZH Support - Posts: 19
Sierra,
I was wondering if this can be done. I have a study that draws a dash on the bar at a specific point and time. Is there a way or something I can do so that when the line is drawn it actually extends forward to cover 2 bars? I know I can use the displacement but that just moves the dash not extends it.
Let me know Thanks again!
[2013-06-07 16:28:37]
How is this programmed. Using Spreadsheets or ACSIL?
[2013-06-07 17:00:10]
It is not coded. I was using the study color bar. But I have found a solution.
Thanks again for the help
