Date/Time: Sun, 22 Dec 2024 05:42:29 +0000
T4 linking with Sierra
View Count: 867
[2015-06-30 19:35:23]
User889413 - Posts: 1
Please help, I confirm a T4 account with sierra access. Username and password confirmed by logging into T4 successfully. Tried with firewall disabled and still unable to connect T4 with Sierra.
Here is log:
CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2015-06-30 13:22:05
CTS FIX - Firm: rjo | 2015-06-30 13:22:05
CTS FIX socket (0) | Resolved address fix.t4login.com to IP 208.116.215.102 | 2015-06-30 13:22:05
CTS FIX socket (50) | Connected. | 2015-06-30 13:22:06
CTS FIX socket (50) | Starting SSL connection. | 2015-06-30 13:22:06
CTS FIX socket (50) | SSL connection established. | 2015-06-30 13:22:06
CTS FIX: Sending the Logon message. | 2015-06-30 13:22:06
CTS FIX: Received a FIX message from an unknown sender. Expected "rjo", but received "". | 2015-06-30 13:22:06 *
FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20150630-19:18:55.47945=1372=A373=1058=Sending Time Accuracy problem10=210 | 2015-06-30 13:22:06 *
CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2015-06-30 13:22:06 *
CTS FIX socket (50) | Closed. No error. | 2015-06-30 13:22:06
FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20150630-19:18:55.47958=FIXLogin Time Tag Accuracy Problem - Out of time window10=250 | 2015-06-30 13:22:06 *
CTS FIX socket (50) | SSL shutdown indicates not able to send 'close notify'. | 2015-06-30 13:22:06
CTS FIX socket (50) | SSL has been shut down. | 2015-06-30 13:22:07
CTS FIX socket (50) | SSL object has been freed. SSL state is now disconnected. | 2015-06-30 13:22:07
CTS FIX socket (50) | Shutdown and closed. | 2015-06-30 13:22:07
CTS FIX: Socket connection was closed without any logout messages sent or received. | 2015-06-30 13:22:07
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-06-30 13:22:07
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-06-30 13:22:07
CTS FIX: DisconnectFIX called. | 2015-06-30 13:22:07
CTS FIX Historical Data: DisconnectFIX called. | 2015-06-30 13:22:07
CTS FIX: Disconnected. | 2015-06-30 13:22:07
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-06-30 13:22:07
File >> Disconnect selected. | 2015-06-30 13:22:08
CTS FIX: DisconnectFIX called. | 2015-06-30 13:22:08
CTS FIX Historical Data: DisconnectFIX called. | 2015-06-30 13:22:08
CTS FIX: Disconnected. | 2015-06-30 13:22:08
[2015-06-30 19:46:54]
The problem is that your computer's clock is not set accurately preventing a connection to the FIX server. Refer to this help topic:
http://www.sierrachart.com/index.php?page=doc/helpdetails75.html
