Date/Time: Fri, 18 Oct 2024 06:15:09 +0000
limit chase with bracket OCO, and MIT attached orders at CTS
View Count: 1422
[2015-06-30 19:04:34] |
User35525 - Posts: 181 |
Does limit chase work with bracket OCO's? I'd like to create an ACSIL study to use limit chase in a bracket OCO at CTS, with attached STP (for stop loss) and MIT (for take profit) orders. Does MIT work now at CTS as an attached order? The CTS T4 Trading Platform page says it does, so I assume "yes", but the Order Types page says "As of this writing, this order type cannot be used as an Attached Order type with the CTS T4 trading platform service." See: http://www.sierrachart.com/index.php?page=doc/CTS_T4.php http://www.sierrachart.com/index.php?page=doc/doc_OrderTypes.html Thanks. |
[2015-06-30 19:12:07] |
Yes, Limit Chase can be used as an Attached Order for all Trading services. The information on the CTS T4 page about MIT orders for Attached Orders is correct. We have updated the Order Types page and removed that old information. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-06-30 19:18:04] |
Is limit chase supported as the parent order in a bracket OCO, with ACSIL? The Order Types page says it's "also supported as an Attached Order", but I was hoping to use it as the parent order in the bracket OCO, since I believe limit orders are the only supported types of parent orders in bracket OCO's at CTS. Thanks. Date Time Of Last Edit: 2015-06-30 19:23:19
[2015-06-30 19:36:04] |
You can use a Limit Chase order as the parent order because externally it is only a Limit order to the trading service.
[2015-07-23 19:49:34] |
Question, is a bracket OCO at CTS completely safe and idempotent in all cases? That is, will the completely-managed-by-CTS order-trio (assuming I send two child orders) always successfully complete with: a) a parent order. b) attached take profit. c) attached stop loss. I'd like to directly set the price for attached child orders using ASCIL, per the samples in tradingsystems.cpp, and I (hope) that a bracket OCO will simply FAIL if CTS cannot handle my requested child orders. TopstepTrader staff told me that with the T4 platform, it's possible to have a naked position (no stop loss) if using an "auto-OCO" or regular OCO. I'm not sure, but think the "auto-OCO" is the same as a "bracket OCO" in Sierra? Also, assuming bracket OCO's are idempotent (either all requested attached orders are filled or all rejected), is it true that Sierra Chart can help mitigate an unfilled bracket with the "chase mechanism", which re-tries the bracket OCO until it successfully fills a position, or finally reaches the maxium chase amount? I'm just trying to see how much extra "management" I need to program in ASCIL. If it's possible to leave myself with a naked position (no stop) then I'll have to program an entry-watchdog of sorts, which manually attaches a stop child order to the naked bracket OCO. Date Time Of Last Edit: 2015-07-23 19:55:00
[2015-07-23 20:11:27] |
When using server side bracket orders in Sierra Chart all we can say is that the main order, and the Target and Stop orders are all sent at once to CTS. What happens after that, is not within Sierra Chart control. So you will need to ask CTS about your question. CTS Auto-OCO is the same as a Bracket order in Sierra Chart. It is submitted to CTS as an Auto-OCO. is it true that Sierra Chart can help mitigate that with the "chase mechanism", which re-tries the bracket OCO until it successfully fills a position, or finally reaches the maxium chase amount? No. Sierra Chart has no mechanism for this and would never retry an order. This is regarded as dangerous. And you should be extremely cautious implementing something like this on your side. We would advise against that. You should instead be notified of this condition and take manual action on that including calling the broker if necessary if there is anything that you see that does not make sense with reported positions or orders. Never trust this to automation.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-23 20:39:42
[2015-07-23 20:24:27] |
I'm a little confused now. I was told above that "chase" would work with parent orders in bracket OCO's. So, the bracket OCO would be managed by Sierra Chart until the parent is filled or not, and I have a real position (#4 post above) or no position. I'm just trying to figure out the safest way to automate my trading. Until now, I've been just sending a parent and then manually attaching the stop, but I'm hoping a bracket OCO is better. It sounds like there's no 100% full-proof way for Sierra Chart to enter without the possibility of a naked position (no stop loss)? If that's true, then how can anybody even auto-trade? Is there an example I've missed regarding how to attach a stop to a naked bracket OCO that filled without a stop? If that's technically feasible then it should be easy to just find the parent ID (either walk the order list or save it in a persistent variable). But, then is attaching a child order later doable? I want to attach a child to an OCO, but see the docs explain how to modify an existing OCO instead: http://www.sierrachart.com/index.php?page=doc/doc_ACSILTrading.html#ModifyingOCOOrders Date Time Of Last Edit: 2015-07-23 20:45:11
[2015-07-24 04:41:54] |
You can use a Limit Chase order for the parent order of a bracket order, but if the bracket order were to be rejected, the Limit Chase functionality ends at that moment in time. If there are any problems with the child orders this will not be changed in any way by using a Limit Chase order. While nothing is 100% certain, certainly using a server-side bracket order is going to be very reliable to a point where we think you should not have a concern about it other than to monitor what the automated trading system is doing. Is there an example I've missed regarding how to attach a stop to a naked bracket OCO that filled without a stop? If that's technically feasible then it should be easy to just find the parent ID (either walk the order list or save it in a persistent variable). But, then is attaching a child order later doable? I want to attach a child to an OCO, but see the docs explain how to modify an existing OCO instead: We really have answered enough about this, and there is not anything more we could really say. We think you making this far too complicated. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-24 04:45:03
