Date/Time: Fri, 11 Sep 2026 07:55:02 +0000
Improper Format
View Count: 1251
[2015-06-30 18:35:23]
User39772 - Posts: 311
For some symbols I get the following error message in the message log:
"Unknown symbol ID 174 is unknown" when I send an order via chart DOM to IB.
I use SC data feed an see [M] in the chart. The problem appears only for some symbols, e.g. MSFT, others work fine like AAPL.
[2015-06-30 20:32:47]
For MSFT, you need to use the symbol format that specifies the exchange and primary exchange. It is documented here:
https://www.sierrachart.com/index.php?page=doc/IBSymbols.html#Stock
When you use this symbol format, the data may not come from the Sierra Chart Exchange Data Feed due to complexity with symbol mapping.
Date Time Of Last Edit: 2015-06-30 20:33:23
[2015-07-01 17:50:48]
Itried:
MSFT-STK-SMART/NASDAQ and MSFT-STK-SMART[NASDAQ and inserted tis into a Quote Board.
If I click on it "Loading historical data" appears in the linked charts but nothing
happens.
Same is valid with: INTC.
To avoid misunderstandings:
If I use MSFT or INTC the SC feed delivers data and I see the charts.
My problem is, if I want to transmit an order from a chart DOM to TWS
the orders do not appear in the TWS API window or another TWS window
and the orders seem to be frozen in the chart until I delete them.
I would be interesting what the problem is. I do not see more complexity
in MSFT or INTU compared to other symbols that work fine.
[2015-07-01 18:05:00]
When you have opened the chart for MSFT-STK-SMART/NASDAQ , and no data appears, provide a copy of the Message Log. Here are instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#log
You will need to contact Interactive Brokers about this.
[2015-07-01 18:12:57]
No:
I have opened a chart for MSFT and data appears in the chart but no order gets to TWS.
If I open a chart with MSFT-STK-SMART/NASDAQ no data appears in the chart.
[2015-07-01 18:17:57]
Yes we understand. This is why we want to see the Message Log to understand why there is no data received for MSFT-STK-SMART/NASDAQ
[2015-07-01 18:29:44]
When I have opened the chart for MSFT-STK-SMART/NASDAQ:
Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\MSFT-STK-SMART[NASDAQ.dly | 2015-07-01 14:25:25
Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\MSFT-STK-SMART[NASDAQ.scid | 2015-07-01 14:25:25
Requesting market depth updates for: MSFT-STK-SMART/NASDAQ if supported. | 2015-07-01 14:25:26
Message from IB: Deep market data is not supported for this combination of security type/exchange. IB Error Code: 10092. Request ID: 100024. | 2015-07-01 14:25:26
Remark:
Since I do not want to use the IB feed for trading I would very much appreciate if that problem could be solved.
[2015-07-04 07:08:09]
see msg log above what do you think
[2015-07-04 07:24:55]
This Message Log does not have enough information for us to answer this. It is incomplete.
