Date/Time: Sun, 22 Dec 2024 05:22:13 +0000
User Questions
View Count: 804
[2015-06-30 18:29:41]
Sierra Chart - Max - Posts: 5756
1) i have 16 days trial period now, I dont see the market depth of 10 levels on the chart dom, I just see the price in the middle. is there some settings I need to do.
2) I understand with transactAT-sc , chart dom feature is not included and I MUST use SC directly, if it is so which package level i need to subscribe package 2 or 3 ?
3) is the chart dom updates are realtime, as fast as it is in the transactAT DOM. I dont mind even it is 30 seconds slow since i dont scalp
Sierra Chart Support
[2015-07-01 18:42:01]
1. These columns need to be added. Refer to:
http://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#CustomizeChartDOMColumns
2. Any Sierra Chart service package will work. They are documented here:
http://www.sierrachart.com/index.php?page=doc/Packages.php
3. Yes. Refer to the Chart Update Interval setting:
http://www.sierrachart.com/index.php?page=doc/doc_GeneralSettings.html#CUI
For the fastest response always use this Support Board. Here are posting instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php
