Date/Time: Sun, 22 Dec 2024 05:36:09 +0000
Chart DOM
View Count: 808
[2015-06-30 15:26:38] |
User39772 - Posts: 311 |
Hello, I want to assign different mouse buttons different order types inside the Chart DOM. Ho can I implement that ? Is it possible to set up key combinations within SC that send orders regarding a symbol that I shown on the chart to the TWS ? |
[2015-06-30 18:07:13] |
None of this is supported. The closest that would be available is documented here: http://www.sierrachart.com/index.php?page=doc/doc_GlobalTradeSettings.html#ChartDOMSettingshart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
