Date/Time: Sun, 22 Dec 2024 05:27:49 +0000
[User Discussion] - filtering on the number bars
View Count: 967
[2015-06-30 14:06:30] |
User60518 - Posts: 106 |
Hi, Is it possible to filter on the bid x ask number bars as you can on the time and sales on 'combine records' - with same time and type - and filtering on volume (e.g. >=50) - this would help to show where the big nubers are trading on the number bars as well as the t&s, Cheers Date Time Of Last Edit: 2015-06-30 14:20:06
[2015-06-30 14:21:07] |
No.
[2015-06-30 14:29:56] |
thanks - are you saying it's impossible or not available?
[2015-07-01 01:30:05] |
having read a little further I can see the option according to the documentation: http://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#VolumeFilterH in chart settings >> advanced settings 2 - there is an option to filter volume - does this setting not work on the number bars? Cheers |
[2015-07-01 02:10:02] |
Those particular filtering settings are available and they do apply to Numbers Bars, but they do not do what you want as we understand. We cannot help further with this. You should also read this information here: http://www.sierrachart.com/index.php?page=doc/doc_ChartDataFiles.html#LargeVolumeTrades The answer to post #3 is that it is not possible, and not reasonable. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-01 02:11:02
