Date/Time: Sun, 22 Dec 2024 05:14:40 +0000
Data Feed
View Count: 894
[2015-06-30 12:28:47] |
User938598 - Posts: 1 |
Hello, I am using a trial acct and am not seeing the option of "Sierra Chart Real Time and Historical Forex and CFD Data Service" to connect to. Consequently I think I am not getting a live real time feed. I am currently connected to "SC Historical Data". What service should I connect to get historical and real time futures data, so that I can get used to trading with your system in real time. Thanks.
[2015-06-30 18:17:07] |
Unless you have a futures trading account futures real-time data is expensive. Refer to: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#CME To use the "Sierra Chart Real Time and Historical Forex and CFD Data Service" service follow the step-by-step instructions here: http://www.sierrachart.com/index.php?page=doc/SCRealTimeFOREX.php#Setup For futures historical data, use the SC Historical Data service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
