Date/Time: Sun, 22 Dec 2024 05:35:48 +0000
6J JPY future data problem
View Count: 1000
[2015-06-30 12:05:16] |
User91568 - Posts: 13 |
Hello, I am using the Sierra Charts Data Feed and have problems with the data for the 6JU5 contract. Prices are not shown correctly. Other markets work without problems. See screenshot attached. How i can fix this? Regards Philipp |
[2015-06-30 13:55:10] |
What exactly is wrong? It appears correct.
[2015-06-30 14:10:48] |
The Chart scale is wrong because it is in 5 tick steps where chart is correctly in 1 tick steps. Same in DOM. DOM is in 5 tick steps and depth is missing.
[2015-06-30 14:13:16] |
its not possible to select prices between
[2015-06-30 14:24:44] |
Select Chart >> Chart Settings. What is the Tick Size set to? depth is missing. Restart Sierra Chart.
[2015-06-30 14:30:36] |
Tick Size was set wrong by default. I reset it to 0.1. Now its working correctly. Thank you |
