Date/Time: Fri, 22 Nov 2024 23:48:43 +0000
ASCIL & Days to display/load
View Count: 1552
[2013-06-07 13:08:31] |
marcovth - Posts: 61 |
Hello ... Is there a way with ASCIL to control the number of "Days to display/load"? If I check a 1 minute chart, I would only like to load 5 days, but if I am looking at 1 hour charts, I would like to automatically load 30 days. Thanks for your replies. |
[2013-06-07 20:58:50] |
This is not supported.
