Date/Time: Thu, 10 Sep 2026 05:00:43 +0000
Study Subgraphs Ratio + Alerts (Color Background based on alert condition) behavior
View Count: 1482
| [2015-06-29 19:12:20] |
| jwick - Posts: 142 |
For some reason I can't seem to form any meaningful alert conditions when referencing a study subgraph ratio. Some relevant observations / notes: 1) A simple test of =id#.sg1 > 0 produces only a few bars as being greater than zero even though if I visually place a horizontal line @ 0, all bars are above it. When I invert the test with id#.sg1<0, all the other bars get highlighted which were previously not highlighted. 2) The study subgraph ratio is dividing a numeric value with a time value (bar duration). Not sure if this makes things wonky? Thanks! |
| [2015-06-29 19:21:50] |
nvm ... figured it out. Problem had to do with the Value Format. When I changed the Value Format in the Study Subgraph Ratio from .01 to 1, then everything worked hunky dory.
