Date/Time: Sun, 22 Dec 2024 05:01:07 +0000
Let me know how to make chart with no gap regardless
View Count: 815
[2015-06-29 12:17:31] |
gold757 - Posts: 39 |
of the gap overnight or over the weekend. I need the chart in which today's open is same as yesterday's close no matter what the magnitude of the gap might be.
Date Time Of Last Edit: 2015-06-29 12:20:38
[2015-06-29 16:32:13] |
You could adjust the historical data in the data file before the open Date-Time, by the difference between the previous close and the next open. Refer to the documentation here: http://www.sierrachart.com/index.php?page=doc/doc_AdjustingData.html#GeneralInformation Refer to Introduction and Add/Subtract Amount on that page. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-06-29 16:32:36
