Date/Time: Sun, 22 Dec 2024 05:36:47 +0000
Update new versions
View Count: 857
[2015-06-29 10:45:18] |
user54342 - Posts: 42 |
Hello, I would like to ask you if it is impotrant for me to still update Sierra and keep it up to date? Will it goes normally even with old versions for example ver.1220 ? Thank you |
[2015-06-29 15:57:58] |
It is a good idea to keep Sierra Chart up-to-date. Here are instructions to update Sierra Chart: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate You can still run version 1220. This is no problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
