Date/Time: Sun, 22 Dec 2024 04:52:47 +0000
Trader DOM Column Definition
View Count: 874
[2015-06-29 02:46:13] |
User43921 - Posts: 1 |
Hello, This may be a simple answer but I am curious what the difference is between Recent Bid/Ask volume and Current Traded Bid/Ask volume found in the Trader DOM column setup page. Thanks! Todd Date Time Of Last Edit: 2015-06-29 02:47:01
[2015-06-29 10:04:36] |
Descriptions can be found here: http://www.sierrachart.com/index.php?page=doc/doc_GlobalTradeSettings.html#ChartDOMColumnDescriptions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
