Date/Time: Sun, 22 Dec 2024 05:28:21 +0000
FYI: Interactive Brokers has a unix java version of TWS
View Count: 2861
[2015-06-29 00:25:39]
bjohnson777 (Brett Johnson) - Posts: 284
Interactive Brokers has a unix java version of Trader Workstation that isn't shown on their info page:
https://www.sierrachart.com/index.php?page=doc/IB.php
I ran it briefly on Ubuntu 14.04 LTS using Oracle Java. I'm running SC under WINE but didn't try to connect to TWS since I can't do anything with the account. (I'm looking forward to an eventual linux version of SC.)
Ubuntu Oracle Java Install Instructions:
http://www.webupd8.org/2012/09/install-oracle-java-8-in-ubuntu-via-ppa.html
Found from these pages:
https://launchpad.net/~webupd8team/+archive/ubuntu/java
https://help.ubuntu.com/community/Java
IB TWS Unix Instructions:
https://www.interactivebrokers.com/en/index.php?f=674&ns=T
If the link changes, it can be found as the regular TWS download option from the main page.
*** Use a linux web browser or the windoze version will come up. I didn't see a way to manually switch between the two.
The command to run it is long. I recommended putting it into a startup script for ease of use. The IBGateway API is run from the same jar file using a different command that's also long.
[2015-06-29 00:47:08]
Thank you for this information.
