Date/Time: Mon, 23 Dec 2024 08:35:06 +0000
Compact Lines In Fill Area For Intraday Studies
View Count: 1657
[2015-06-27 13:25:02]
cmet - Posts: 565
Is it possible to plot studies which create intraday levels (Initial Balance, Daily OHLC, TPO Value Area Lines, etc) in the fill space instead of across the chart?
A lot of platforms have a "compact lines" or some similar option in the indicator settings that allow you to plot them this way.
For example, instead of something like this: http://s9.postimg.org/gsma6ljnz/lines_full.jpg
You can have something like this: http://s3.postimg.org/8vm9blvjn/lines_compact.jpg
The Current Price Line study has this ability in that you can choose to "Display Current Line on Chart Bars". If you select no, it only plots it in the fill area.
Can this be added to the following:
Initial Balance
Daily OHLC
High/Low for Time Period(-Extended)
Highest High/Lowest Low Over N Bars
Horizontal Lines
Pivot Points Variable Period
Study/Price Overlay
Study Overlay - OHLC
Weekly OHLC
Thanks.
Date Time Of Last Edit: 2015-06-27 13:32:29
[2015-06-27 20:49:59]
We initially marked this as a user discussion because of the extensiveness and complexity of the request.
However, there may be an easy way this can be done universally for all studies and we will see about that.
[2015-06-27 21:29:00]
cmet - Posts: 565
That would be fantastic. Please update this thread when a decision is made.
[2015-07-30 15:57:34]
cmet - Posts: 565
Have there been any decisions made regarding this?
[2015-07-31 18:53:09]
This will be done but we have not had a chance to do it yet.
[2015-08-02 17:13:09]
User13668 - Posts: 294
I support this request.
But in the meantime I have been using a work around that nearly gets you there. In my case it is fine as i don't use a very wide fill space.
Basically I use the Short Name field in the Sub Graphs settings of the Study.
See attached to Pictures showing Yesterday's H/L/C.
imageFill Space.JPG / V - Attached On 2015-08-02 17:12:46 UTC - Size: 19 KB - 464 views
imageFill space2.JPG / V - Attached On 2015-08-02 17:12:54 UTC - Size: 112.2 KB - 391 views
[2015-09-25 16:26:23]
cmet - Posts: 565
Hast his made it onto the "to do" list yet? I keep asking because you mentioned that "there may be an easy way this can be done universally for all studies" a few months ago.
[2015-09-25 16:30:34]
Looks like it might be in the latest release, although I have not downloaded to check it.
https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer1299
[2015-09-25 17:24:13]
Version 1299 has a new Draw Style to accomplish what you requested. Refer to the What is New webpage for more information.
Date Time Of Last Edit: 2015-09-25 17:24:57
[2015-09-25 17:35:47]
cmet - Posts: 565
Fantastic. Thank you.
