Date/Time: Sun, 22 Dec 2024 05:01:12 +0000
Unknown lines
View Count: 853
[2015-06-26 23:03:30] |
TekDiver609 - Posts: 20 |
This is a 5 min destination chart. It has 3 lines on it- red, white, and green, that I have now idea what they are? ha ha, I don't know what to send you because I don't know where they originate from. I've checked all the source charts and there is no lines or studies that would do this. I would like to remove them. What do you suggest? http://www.sierrachart.com/image.php?l=143535907372.png Thanks Date Time Of Last Edit: 2015-06-26 23:05:49
[2015-06-27 02:11:02] |
Remove all the studies from the chart. Do they go away?
[2015-06-27 02:20:44] |
Yes. I just got done duplicating the chart and began removing one by one: each source chart. No change. Went to the studies and removed until I found it was the Initial Balance study. Is there a way to limit the lines to show just the time defined in the study? I have the IB Study start time set to 08:30:00 and end time set to 09:29:59. Chart Settings Intraday 0-5-0, start time 08:30:00, end time 14:59:59 (CST). Evening session start 15:00:00 end time 08:29:59. Thanks |
