Date/Time: Sun, 22 Dec 2024 05:41:00 +0000
Add/Remove symbols in quote spreadsheet, from ACSIL ?
View Count: 941
[2015-06-26 19:25:29] |
wwwingman - Posts: 185 |
Hi Can I write into a quote spreadsheet from an ACSIL study ? I am looking to add and remove, dynamically, the list of the symbols to quote. -- W. Date Time Of Last Edit: 2015-06-26 19:25:46
[2015-07-01 12:26:21] |
As far as I can see, there is no possibility today of writing from an ACSIL study into a quote spreadsheet. -- w. |
[2015-07-01 17:34:24] |
Yes, this is correct. We may add this capability but it has not yet been done.
