Date/Time: Sat, 23 Nov 2024 00:22:42 +0000
custom indicator AC
View Count: 1999
[2013-06-07 08:24:16] |
942abel - Posts: 7 |
hello my question is on a custom indicator. I have the problem that the graphical representation is different from another platform. The indicator is a variation of AC Oscillator. The formula of the other platform is: AO = SMA (median price, 5)-SMA (median price, 34) AC = AO-SMA (AO, 5) And this is the code: //---- indicator settings
#property indicator_separate_window #property indicator_buffers 3 #property indicator_color1 Black #property indicator_color2 Green #property indicator_color3 Red //---- indicator buffers double ExtBuffer0[]; double ExtBuffer1[]; double ExtBuffer2[]; double ExtBuffer3[]; double ExtBuffer4[]; //+------------------------------------------------------------------+ //| Custom indicator initialization function | //+------------------------------------------------------------------+ int init() { //---- 2 additional buffers are used for counting. IndicatorBuffers(5); //---- drawing settings SetIndexStyle(0,DRAW_NONE); SetIndexStyle(1,DRAW_HISTOGRAM); SetIndexStyle(2,DRAW_HISTOGRAM); IndicatorDigits(Digits+2); SetIndexDrawBegin(0,38); SetIndexDrawBegin(1,38); SetIndexDrawBegin(2,38); //---- 4 indicator buffers mapping SetIndexBuffer(0,ExtBuffer0); SetIndexBuffer(1,ExtBuffer1); SetIndexBuffer(2,ExtBuffer2); SetIndexBuffer(3,ExtBuffer3); SetIndexBuffer(4,ExtBuffer4); //---- name for DataWindow and indicator subwindow label IndicatorShortName("AC"); SetIndexLabel(1,NULL); SetIndexLabel(2,NULL); //---- initialization done return(0); } //+------------------------------------------------------------------+ //| Accelerator/Decelerator Oscillator | //+------------------------------------------------------------------+ int start() { int limit; int counted_bars=IndicatorCounted(); double prev,current; //---- last counted bar will be recounted if(counted_bars>0) counted_bars--; limit=Bars-counted_bars; //---- macd counted in the 1-st additional buffer for(int i=0; i<limit; i++) ExtBuffer3[i]=iMA(NULL,0,5,0,MODE_SMA,PRICE_MEDIAN,i)-iMA(NULL,0,34,0,MODE_SMA,PRICE_MEDIAN,i); //---- signal line counted in the 2-nd additional buffer for(i=0; i<limit; i++) ExtBuffer4[i]=iMAOnArray(ExtBuffer3,Bars,5,0,MODE_SMA,i); //---- dispatch values between 2 buffers bool up=true; for(i=limit-1; i>=0; i--) { current=ExtBuffer3[i]-ExtBuffer4[i]; prev=ExtBuffer3[i+1]-ExtBuffer4[i+1]; if(current>prev) up=true; if(current<prev) up=false; if(!up) { ExtBuffer2[i]=current; ExtBuffer1[i]=0.0; } else { ExtBuffer1[i]=current; ExtBuffer2[i]=0.0; } ExtBuffer0[i]=current; } //---- done return(0); } I have modified and created the code for sierrachart, but as I said before the graphical representation is not the same. This is the modified code: /*****************************************************************************
For reference, please refer to the Advanced Custom Study Interface and Language documentation on the Sierra Chart website. *****************************************************************************/ /// AO = SMA(median price, 5)-SMA(median price, 34) /// AC = AO-SMA(AO, 5) // This line is required. Change the text within the quote // marks to what you want to name your group of custom studies. SCDLLName("Custom Study DLL") SCSFExport scsf_AC_DC_Histogram3(SCStudyInterfaceRef sc) { SCSubgraphRef ACDC = sc.Subgraph[0]; SCSubgraphRef Temp3 = sc.Subgraph[3]; SCSubgraphRef Temp4 = sc.Subgraph[4]; SCSubgraphRef Temp5 = sc.Subgraph[5]; SCInputRef InputData = sc.Input[0]; SCInputRef MA1Length = sc.Input[2]; SCInputRef MA2Length = sc.Input[3]; SCInputRef MA4Length = sc.Input[5]; if (sc.SetDefaults) { sc.GraphName = "AC/DC Histogram 3"; sc.GraphRegion = 1; sc.ValueFormat = 3; sc.AutoLoop = 1; sc.FreeDLL = 0; ACDC.Name = "AC/DC3"; ACDC.DrawStyle = DRAWSTYLE_BAR; ACDC.SecondaryColor = RGB(255,0,0); ACDC.AutoColoring = AUTOCOLOR_SLOPE; ACDC.DrawZeros = false; InputData.Name = "Input Data"; InputData.SetInputDataIndex(SC_LAST); MA1Length.Name = "Moving Average 1 Length"; MA1Length.SetInt(34); MA1Length.SetIntLimits(1, MAX_STUDY_LENGTH); MA2Length.Name = "Moving Average 2 Length"; MA2Length.SetInt(5); MA2Length.SetIntLimits(1, MAX_STUDY_LENGTH); MA4Length.Name = "Moving Average 4 Length"; MA4Length.SetInt(5); MA4Length.SetIntLimits(1, MAX_STUDY_LENGTH); return; } sc.DataStartIndex = max(MA1Length.GetInt(), MA2Length.GetInt()) + MA4Length.GetInt(); sc.SimpleMovAvg(sc.BaseDataIn[InputData.GetInputDataIndex()], Temp3, MA1Length.GetInt()); sc.SimpleMovAvg(sc.BaseDataIn[InputData.GetInputDataIndex()], Temp4, MA2Length.GetInt()); if (sc.Index > 0) Temp5[sc.Index] = Temp4[sc.Index] - Temp3[sc.Index]; sc.SimpleMovAvg(Temp5, ACDC, MA4Length.GetInt()); } someone could help me? Thank you so much |
[2013-06-07 12:58:37] |
vegasfoster - Posts: 444 |
I dunno about the other code, but to match the original formula, add a Temp6 subgraph, change the last line, and add another line as follows: SCSubgraphRef Temp6 = sc.Subgraph[6]; sc.SimpleMovAvg(Temp5, Temp6, MA4Length.GetInt()); ACDC[sc.Index] = Temp5[sc.Index] - Temp6[sc.Index]; Date Time Of Last Edit: 2013-06-07 12:59:06
[2013-06-10 14:41:18] |
hello again I changed the last line (as dialogue / /) and I've added what you indicated me, but I get error. this error: error: expected constructor, destructor, or type conversion before '(' token
-- End of Build -- /*****************************************************************************
For reference, please refer to the Advanced Custom Study Interface and Language documentation on the Sierra Chart website. *****************************************************************************/ /// AO = SMA(median price, 5)-SMA(median price, 34) /// AC = AO-SMA(AO, 5) // This line is required. Change the text within the quote // marks to what you want to name your group of custom studies. SCDLLName("Custom Study DLL") SCSFExport scsf_AC_DC_Histogram3(SCStudyInterfaceRef sc) { SCSubgraphRef ACDC = sc.Subgraph[0]; SCSubgraphRef Temp3 = sc.Subgraph[3]; SCSubgraphRef Temp4 = sc.Subgraph[4]; SCSubgraphRef Temp5 = sc.Subgraph[5]; SCSubgraphRef Temp6 = sc.Subgraph[6]; SCInputRef InputData = sc.Input[0]; SCInputRef MA1Length = sc.Input[2]; SCInputRef MA2Length = sc.Input[3]; SCInputRef MA4Length = sc.Input[5]; if (sc.SetDefaults) { sc.GraphName = "AC/DC Histogram 3"; sc.GraphRegion = 1; sc.ValueFormat = 3; sc.AutoLoop = 1; sc.FreeDLL = 0; ACDC.Name = "AC/DC3"; ACDC.DrawStyle = DRAWSTYLE_BAR; ACDC.SecondaryColor = RGB(255,0,0); ACDC.AutoColoring = AUTOCOLOR_SLOPE; ACDC.DrawZeros = false; InputData.Name = "Input Data"; InputData.SetInputDataIndex(SC_LAST); MA1Length.Name = "Moving Average 1 Length"; MA1Length.SetInt(34); MA1Length.SetIntLimits(1, MAX_STUDY_LENGTH); MA2Length.Name = "Moving Average 2 Length"; MA2Length.SetInt(5); MA2Length.SetIntLimits(1, MAX_STUDY_LENGTH); MA4Length.Name = "Moving Average 4 Length"; MA4Length.SetInt(5); MA4Length.SetIntLimits(1, MAX_STUDY_LENGTH); return; } sc.DataStartIndex = max(MA1Length.GetInt(), MA2Length.GetInt()) + MA4Length.GetInt(); sc.SimpleMovAvg(sc.BaseDataIn[InputData.GetInputDataIndex()], Temp3, MA1Length.GetInt()); sc.SimpleMovAvg(sc.BaseDataIn[InputData.GetInputDataIndex()], Temp4, MA2Length.GetInt()); if (sc.Index > 0) Temp5[sc.Index] = Temp4[sc.Index] - Temp3[sc.Index]; ///sc.SimpleMovAvg(Temp5, ACDC, MA4Length.GetInt()); sc.SimpleMovAvg(Temp5, Temp6, MA4Length.GetInt()); ACDC[sc.Index] = Temp5[sc.Index] - Temp6[sc.Index]; } what is wrong? thank you very much |
[2013-06-10 15:20:17] |
Missing header and need to change dll name, change the beginning of the file as follows, #include "sierrachart.h" SCDLLName("ACDC") |
