Date/Time: Sun, 22 Dec 2024 05:40:58 +0000
[User Discussion] - V by P global setting
View Count: 849
[2015-06-25 18:50:41]
conr - Posts: 204
Is there a global setting or something like that within the volume by price settings so that I can make one change? I'm running several charts of the same symbol and would like to be able to change profile dates one time instead of all the charts. If not can you add that?
Thanks.
[2015-06-25 21:00:16]
This does not exist and there are no plans for this.
The closest thing is to use the Chart Linking feature and link the Studies. This is documented here:
https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#LinkNumber
[2015-06-25 22:34:44]
conr - Posts: 204
Why? Is it that difficult to do? A pain in the ass as is.
[2015-06-26 18:51:04]
This is completely far removed from the design logic of studies. We never foresee this being added.
