Date/Time: Sun, 22 Dec 2024 05:13:03 +0000
How to include a custom xxx.dll for object to be push onto Sierra Chart
View Count: 852
[2015-06-25 12:49:48] |
User17709 - Posts: 5 |
Hello Support, I got a myself set up with a file Compass Institutinal - Levels.dll on my laptop some time ago. Can't remember the step. I had print screen (1) the chart to show you the "object" that is pushed to Sierra chart (2) the study price screen. I still got the Compass Institutinal - Levels.dll file, just cannot figure out how to do it with Sierra chart Appreciate your step by step guide Thanks, J C |
Private File Private File Private File |
[2015-06-25 16:58:18] |
This is documented here: http://www.sierrachart.com/index.php?page=doc/doc_DLLUsage.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
