Date/Time: Fri, 22 Nov 2024 23:28:26 +0000
Synchronization with OEC
View Count: 1802
[2013-06-07 07:13:26] |
Michaela Nepovimova - Posts: 8 |
Good morning, sometimes happens, that the stream data from OEC are not synchronized tick by tick with SC. How to ensure it before each trading session to be really sure that it works well? Thanks in advance. Have a nice day, Misa |
[2013-06-07 07:23:21] |
This is not clear enough for us. We are not really sure exactly what the problem you are trying to describe is.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-06-07 07:23:33
[2013-06-07 16:08:43] |
Sierra Chart - Max - Posts: 5730 |
I mean, that when I look at OEC graph and at the same time at SC graph there
are at the same time different tick data. Sometimes SC data are frozen so there is not time and of course tick synchronization. Sierra Chart Support |
[2013-06-07 16:10:03] |
You may be exceedingly OEC 5 symbol limit. How many different symbols are you looking at within Sierra Chart?
