Date/Time: Sun, 22 Dec 2024 05:53:56 +0000
Any idea what this is?
View Count: 786
[2015-06-25 11:57:26] |
infpz - Posts: 826 |
I can't right click to delete, indicating it's not a drawing, and when I hide the only 2 studies on the chart, it is still visible. I might just be spacing out, but what is this? Thanks, PZ Date Time Of Last Edit: 2015-06-25 11:57:40
[2015-06-25 16:45:35] |
This looks like it is from a Time Expansion/Projection Chart drawing. Select Tools >> Manage Chart Drawings Window and locate that drawing and Delete it that way. Here is the documentation: http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ManageChartDrawings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-06-25 16:54:56
