Date/Time: Sun, 22 Dec 2024 11:44:34 +0000
Using two data feeds with the same instance of Sierra Charts
View Count: 834
[2015-06-25 04:36:58]
User980515 - Posts: 1
I'm currently using the CQG FIX data feed to trade futures. I would also like to trade forex on SC, maybe using the FXCM FIX data feed.
Can I run both of these data feeds on the same instance of SC or do I have to use two instances of SC - one for each data feed?
[2015-06-25 09:51:55]
You need to use two separate copies of Sierra Chart:
http://www.sierrachart.com/index.php?page=doc/MultipleServices.html
