Date/Time: Sat, 26 Sep 2026 11:12:57 +0000
Settings for TPO Profile Chart
View Count: 2095
| [2015-06-24 20:32:31] |
| Seanz - Posts: 17 |
Would like to set up a Daily TPO Profile Chart with 2 seperate Profiles 1) 9:30 to 16:15 and 2) 16:30 - 9:29:59. Seems like it should be straight-forward but I can't seem to get it. I have those times set-up in 'Chart Settings' but because use evening session is checked, all I get is one profile beginning at 16:30. I tried using Custom Sub periods set to the times I want but that doesn't change anything? I have Number of TPO Profile Periods set to - Multiple Periods Fixed? I have Profile Time Period Length Unit set to Days and Time Period Length set to 1. What am I doing wrong? appreciate your help. |
| [2015-06-24 22:45:58] |
This is explained here: http://www.sierrachart.com/index.php?page=doc/doc_TPOVolProfileCharts.html#DayEveningSeparateProfiles Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
