Date/Time: Sun, 22 Dec 2024 10:59:56 +0000
Chart Settings
View Count: 773
[2015-06-24 19:58:14] |
Crtfyd - Posts: 278 |
vs1261 What's the difference between "Start of Session" and "Start of Trading Day" in the Chart Settings>Advanced Settings 2>Vertical Grid Lines? My Chart session times are 9:00-12:00 I want to put a vertical line at the open of RTH (9:30) When I select Start of Session or Start of Trading the line is in the same place (9:00) I would think Start of Trading would be RTH? Future versions: Maybe adding RTH as an option? |
Private File |
[2015-06-25 03:04:01] |
They are the same when there is not an evening session being used. We will document them more clearly.
