Date/Time: Sun, 22 Dec 2024 11:11:28 +0000
Study Sets Help Please
View Count: 878
[2015-06-24 15:52:43]
djcurcio - Posts: 236
I created two study sets - Set A and Set B.
I have a chart that includes some studies that are not in either Set A or Set B.
When I apply Set A it eliminates all studies that were previously in the chart.
When I apply Set B it also eliminates all studies that were previously in the chart.
What I wanted was to have the plication of Set A and/or Set B to be additive to the studies already on the chart.
How can I do this?
Also, is there a way to hide a study set without having to hide all the individual studies?
[2015-06-24 23:03:23]
Sawtooth - Posts: 4141
If the Study Collection filename has a '-' at the end of the name, just before the .StdyCollct, it will prompt you to choose whether to 'Clear Existing Studies On Chart?', e.g. example-.StdyCollct
You can simple rename the file, or save another set and add a '-' at the end of the name, or check 'Prompt to Remove Existing Studies'.
http://www.sierrachart.com/index.php?page=doc/doc_StudyCollections.html
