Date/Time: Sun, 22 Dec 2024 11:17:46 +0000
Ответьте по-русски
View Count: 893
[2015-06-24 13:55:36] |
User925359 - Posts: 1 |
Подскажите пожалуйста. При выставлении ордера всплывает следующая ошибка:Trade Order Error: The order quantity for the Parent is 1 and this is less than the total order quantity of 2 for the Attached Orders. Adjust the order quantities so the parent is greater or equal to the Attached Orders. | 2015-06-24 13:52:48 *
[2015-06-24 17:49:30] |
If the parent order quantity is 1, there can only be 1 Target and 1 Stop Attached Orders. The quantity for the Target and the Stop must not be greater than 1. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-06-24 17:49:47
