Date/Time: Sun, 22 Dec 2024 05:22:00 +0000
[User Discussion] - Mapping DOMs to keys
View Count: 967
[2015-06-24 12:59:58] |
rhovega - Posts: 279 |
It is possible to map execution instructions to keys for a chart. Any suggestion in how to map execution instructions for a DOM rather than a chart? I would like to map multiple DOMs to an execution keypad. Thanks |
[2015-06-24 18:06:51] |
You can set up keyboard shortcuts for various trading commands. This is documented here: http://www.sierrachart.com/index.php?page=doc/doc_TradeWindow.html#KeyboardShortcuts These also work identically for Trade DOM. Just make sure the keyboard shortcuts are enabled on the Trade menu. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-06-24 21:34:20] |
Thank you. I use multiple DOMs. Is it possible to map multiple DOMs, individually? (eg, buy at market ES with "alt+q" and buy at market ZB with "alt+w"). Or is it only possible to make system-wide mapping?
[2015-06-24 21:39:28] |
No, this is not supported at all.
[2015-07-01 00:16:41] |
Futures Operator - Posts: 239 |
Could you consider adding this functionality of a shortcut to make a specific window and also a shortcut to make a specific chartbook active? For anyone who trades multiple markets, trading keyboard shortcuts are not very useful if they still require use of two hands, mouse movement and clicking first before using the keyboard shortcut. This would be a huge improvement to trading shortcuts in Sierra Chart.
Date Time Of Last Edit: 2015-07-01 14:47:07
