Date/Time: Sun, 22 Dec 2024 11:28:43 +0000
interface between two sessions
View Count: 780
[2015-06-24 12:31:18] |
jimnovak - Posts: 42 |
is there anyway to have two separate sessions of sierra communicate? for instance; i have a session running for my analysis in which i use a quote board to select/choose a symbol (lets call it 'analysis'). i also have another session connected to my broker for placing trades.(lets call it 'live') question is when i choose a symbol in analysis session, can the live also get triggered to show the same? maybe use some sort of api to write code to pass the symbol. mind you my broker and sc data use different codes to trigger of same symbol. for instance sc uses eurusd where my broker uses eur.usd-cash-idealpro to invoke the same chart. |
[2015-06-24 18:07:35] |
The closest that is available is to use the data sharing feature. This is documented here: http://www.sierrachart.com/index.php?page=doc/MultipleServices.html#Sharing Although this will not do exactly what you want. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-06-24 18:07:47
