Date/Time: Sun, 22 Dec 2024 11:45:18 +0000
Time frame stuck in 5 min
View Count: 822
[2015-06-24 00:44:59] |
User53283 - Posts: 6 |
When I add a new chart it opens in 5 min, when I change the time frame it loads the new time frame for half a second and then returns to the 5 min chart. This happens on any time frame change from the 5 min. Thanks, Gary |
[2015-06-24 02:17:58] |
The solution to this is explained here: Unable to Change the Bar Time Period for Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
