Date/Time: Sat, 12 Sep 2026 11:52:05 +0000
daily candle close
View Count: 1526
| [2015-06-23 21:49:51] |
| User49421 - Posts: 21 |
Hi, I set my charts to new York time so that the daily candle closes at 11 BST which is 10 GMT. However I noticed that the candle closed at 10 BST which is 9 GMT. The daily close candle on forex should be at 10 GMT how do I fix this. |
| [2015-06-24 04:19:11] |
This cannot be changed unless you set up an Intraday chart. Refer to this page: http://www.sierrachart.com/index.php?page=doc/helpdetails12.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-06-24 05:47:24] |
Here are instructions to set up an Intraday chart to do this: http://www.sierrachart.com/index.php?page=doc/doc_SessionTimes.php#CreatingDailyBars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
