Date/Time: Mon, 16 Sep 2024 19:15:49 +0000
Same data producing different charts?
View Count: 729
[2015-06-23 15:18:28] |
User20683 - Posts: 12 |
Why am I getting two different charts when using the same 600 contract volume bar settings for the emini DOW futures today? My data source is IQ. I would expect that the trades data should be identical. Thanks |
chart2.png / V - Attached On 2015-06-23 15:16:34 UTC - Size: 54.07 KB - 273 views Attachment Deleted. |
[2015-06-23 18:17:21] |
Make sure the Chart >> Chart Settings >> Session Times settings are the same between the two charts. There must be some difference there.
