Date/Time: Sun, 22 Dec 2024 11:39:44 +0000
SC historical data service and historical intraday data
View Count: 894
[2015-06-23 14:18:17] |
natanibz - Posts: 135 |
Hello, is it possible to have more historical intraday data, for example from 2003 like historical daily data, for the most popular contract, with SC historical data service ? Thanks |
[2015-06-23 19:19:44] |
No. Not that far back for intraday data.
[2015-06-24 11:21:21] |
I have seen that historical daily data are increased for some popular contract. They start from 2003, some months ago they started from 2009. Is it possible that in the future you increase also historical intraday data? |
[2015-06-24 17:08:34] |
No, this will not be possible.
