Date/Time: Tue, 22 Sep 2026 18:32:20 +0000
How to get daily movingAverage into strategy running on minute timeframe in replay?
View Count: 1098
| [2015-06-23 09:37:44] |
| Duke - Posts: 3 |
I have a strategy in a minute timeframe that is using movingAverage indicator on daily chart. During replay I haven't succeeded to get correct data from MA. I guess its thanks to that daily timeframe is in "now" while minute is being replayed in history, hence I get same data from indicator no matter the time in replay. Is there a way to get correct indicator data both for replay and realtime? Thanks. |
| [2015-06-23 19:44:41] |
Yes. Use the Study/Price Overlay study. There are certain Input settings that need to be set for that study for this to work properly. Refer to the documentation for the study for more information: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s118 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
